Installation Guide for Cisco ACI Simulator 6.0.3d
tomy.tim
Cisco ACI Simulator 6.0.3d Installation Guide
The Cisco ACI (Application Centric Infrastructure) Simulator is a valuable tool for simulating ACI environments before actual implementation. In this guide, we will walk through the installation of Cisco ACI Simulator version 6.0.3d.
System Requirements
Ensure your system meets the minimum requirements before starting the installation:
- Operating System: Linux (recommended), Windows, or macOS
- RAM: Minimum of 32 GB
- Disk Space: Minimum of 100 GB
- Processor: Intel(R) Xeon(R) CPU ES-2697 @ 2.60GHz 2.81 GHz or higher
Installation Steps
1. Download Cisco ACI Simulator:
1.1. Visit the Cisco download portal.
1.2. Locate and download version 6.0.3d of the Cisco ACI Simulator.
2. Extract Files:
Extract the contents of the downloaded file to a directory of your choice.
3. Initial Configuration:
3.1. Navigate to the directory where the files were extracted.
3.2. Run VMware and extract the acisim-6.0-3d file, then perform the initial configuration following on-screen instructions.
4. Initial Configuration:
4.1. Navigate to the directory where the files were extracted.
4.2. Run VMware, extract the acisim-6.0-3d file, and perform the initial configuration following the on-screen instructions.
5. Open the merged file on the VMware workstation.
6. Start the Simulator:
6.1. After configuration, launch the Cisco ACI Simulator.
6.2. Wait until the simulation is fully loaded.
Note
If an error related to "SHA digest of file acism-6.0-3d-disk1.vmdk" occurs during execution, you can find the solution to this issue in my article at https://community.cisco.com/t5/artigos-data-center-e-cloud/como-instalar-o-cisco-aci-simulator-6-0-3d-no-vmware-workstation/ta-p/4966114
7. Power on the newly created VM
7.1. Open a browser and access the simulator's graphical interface using the address provided during setup. The waiting time will depend on the hardware capacity; in my case.
7.2. Keep the default settings whenever necessary, except for the IP and gateway address.
7.3. Do not change Infra VLAN 4, as it is necessary for switch discovery.
 7.4. After filling in the data, proceed to set a password.tomytim_5-1704678192193.png
8. Log in to the web GUI using the password set in step 7.3.
9. Click on "Begin" in Fabric Membership.
10. Switches will appear one by one, so be patient. Click on "Register," add the node ID, switch name, and node type, then submit.
10.1. Click continue, and in the next window, close the initial configuration.
11. Repeat this process to register the remaining switches by clicking the Update button in the pop-up window.
12. Other parameters, such as BGP and NTP, can be configured according to your needs, as they are required in a production environment. Since this is a test simulator, I'll skip and close the window.
13. My suggestion is to complete the registration process for all nodes outside the quick configuration and do it through the ACI GUI, as illustrated in the image below. This is because, in this setup, node registration is significantly faster.
14. Check if the fabric has been created and view the topology.
The fabric is connected. An important aspect to note is that every time the VM is restarted, it will lose the configuration.
15. Access to Leaf/Spines
1. Log in to the APIC using the administrator account via SSH.
2. Execute the "acidiag fnvread" command to view the TEP IP.
3. SSH into admin@<TEP IP> and use the same password as the APIC.
If you liked the article, don't forget to leave a kudos and subscribe and share your knowledge.
#routingfriends #tomytim #CiscoACI #Networking ##Cisco #Simulation #VMWareWorkstation #NetworkInfrastructure
Tomy Tim
10 Replies 10
AshSe
Dear @tomy.tim
Does this simulator provide Data Plane connectivity and this reachability test between "End Points"?
@AshSe LabHandsOn Master the Future of the Data Center with CISCO ACI: Learn the Secrets of the Solution
I have a youtube channel @routingfriends where we talk a bit more about the subject, you can put the subtitles in English.
https://www.youtube.com/watch?v=ppbSoHDQ3HE
Tomy Tim
🎙️🔥 Estamos animados para anunciar nosso próximo convidado no podcast Routing Friends! 🚀 👨‍💼 Marcelo Alcantara estará conosco, trazendo mais de 15 anos de experiência em concepção, desenvolvimento e implementação de soluções de Data Center. 🏢💻 Além disso, ele é um instrutor certificado pel...
Could you please let me know, if End Point to End Point testing/reachability is possible in ACI Simulator v6.0.3d?
Data path endpoint testing is not possible on virtual ACISIM. Cisco did have an ACISIM appliance you could connect ESXi hosts to it to test data plane but End of Sale 2019
shahi22
what should i do if i want to access each leaf, spine to show its config and sh vxlan config that make fabric Interconnect?
Hi @shahi22
Looks like you are asking a new question.
This post is very old. Trying to resurrect old threads doesn't help anyone. You can read my views on this here.
RedNectar aka Chris Welsh.
okay ya @RedNectar, thanks for the note, I'll make sure to start a new post next time instead of replying to an old thread, still learning, and I appreciate the guidance.
tomy.tim
@shahi22The ACI simulator doesn’t allow direct access to the leaf or spine switches. It's limited to the APIC and control plane functions, so you can't run CLI commands like show vxlan on the fabric nodes.
Tomy Tim
Hi Tom,
very much appreciate your contributions.
I have a question on the fabric membership, after Spine and Leaf are added - but it shows Inactive - version 5.1.3
any suggestions?
@msayed01
Hi, thanks for your question.
In the ACI Simulator, even if you add Spine and Leaf nodes to the fabric membership, they will usually remain Inactive. This is a limitation of the simulator: it does not bring up the real control/forwarding plane, so nodes cannot reach an “active” state as in physical hardware.
The simulator is mainly intended for policy modeling, tenant configuration, and GUI/API exploration, not for validating underlay/overlay protocols or fabric forwarding. That’s why the membership status stays “Inactive.”
If you want to practice a full fabric bring-up (with active nodes and VXLAN configurations), you would need a real ACI lab or virtual integration with hardware.
Greetings!
Tomy Tim
