Integrate ACI Simulator with vmware VCA using Mgmt Tenanant using the
Ibrahim Jamil
Level 6
Level 6
Hi Freinds
I Heard that u can Integrate ACI Simulator with vmware VCA using Mgmt Tenanant using the the Mgmt IPs for both ! so that you can push PG to VC and Play Around , any walk around
5 Replies 5
abhjha2
Hi Ibrahim,
Yes, that's true and you can learn more using the below labs on dCloud-lab
Cisco ACI 5.2 with VMware Lab v1
Cisco ACI 6.0 with VMware v1
Getting Started with Cisco ACI 5.2 v1
Getting Started with Cisco ACI 6.0 v1.1
AJ
If you find my reply solved your question or issue, kindly click the 'Accept as Solution' button and vote it as helpful.
You can also learn more about Cisco ACI through our live Ask the Experts (ATXs) session. Check out the ATXs Resources [https://community.cisco.com/t5/data-center-and-cloud-knowledge/cisco-aci-ask-the-experts-resources/ta-p/4394491] to view the latest schedule for upcoming sessions, as well as the useful references, e.g. online guides, FAQs.
But how can i do it using my homelab ACI Sim with VCA
Deploy a VCSA VM, Setup the ACI Sim and ensure IP connectivity between the two.  It's not complicated.  Without any details around your homelab, can't really provide any greater detail.
Robert
Hi robert
thanks for ur reply
VCSA VM, Setup the ACI Sim and ensure IP connectivity between the two  already in place
Can y pls pls provide step by step
Following the VMM integration guide.  There's no difference in the process between a real Fabric and the Sim from this point on.
https://www.cisco.com/c/en/us/td/docs/dcn/aci/apic/6x/virtualization/cisco-aci-virtualization-guide-60x/ACI-Virtualization-Guide-60x-aci-with-vmware-vds.html
Robert
