02-27-2018 08:39 AM - edited 03-01-2019 05:27 AM
Hello team! Is there any way to mask faults in ACI? Some of them are the following:
F0532 port down
F0135 disruptive external operation in EPG
F1296 VPC down
Thanks in advance!
02-27-2018 08:47 AM
03-08-2018 06:03 AM
Sorry for the delay! That link is so useful.
04-12-2018 12:45 PM
Was anyone able to squelch F1296?
I was not able to find the correct monitoring object. fltVpcIfIfDown should be under the physical object ethpm, where you can find F0532. Trying to find the correct one, I checked most of the other objects to find code F1296.
04-19-2018 06:34 AM
05-10-2018 09:42 AM
For those looking for F1296, it is under the "Fabric Policies" monitoring policy. The monitoring object you need to select is "VPC Interface (vpc.if)". Then you will have the option to squelch F1296.
