L3OUT over VPC for interconnection with FW Active/Standby
oscar.sanchez.g
I have a solution with two FWs in VPC towards two LEAFs, these FWs work Active-Passive. Will be possible to configure L3OUT on these VPCs to handle high availability?
11 Replies 11
Sergiu.Daniluk
Hi @oscar.sanchez.g
Sure. Single L3Out, SVI configured on the two Leaf switches. Next hop via VIP of the FW. The active FW will respond to ARP. When the failover happens, the new FW will take over the traffic.
Let me know if you have any questions.
Stay safe,
Sergiu
I make the following configuration on the L3OUT. In each VPC I configured the same SVI, and the same addressing, additional I configured static route (default) pointing to the Firewall.
I have no way now to test the FW switch, but I would like to know if this is the best way to configure in this scenario.
Yes. Looks good. And I believe on the firewall, you have the next hop the secondary IP cfg of the ACI, right?
Sergiu
please, if are using OSPF between firewall and leaf, is it same solution?
no, it is static routing
Yeah that's right
1) I know it's static route, but in case we use dynamic routing (ospf) could we follow same configuration here without default route next hope VIP of the firewall?
2) this solution support only SVI interface?
if you connect the FW in VPC, this means you need to configure SVIs on ACI.
If you use OSPF, then the routing protocol will take care of the next hop ^_^
Stay safe,
Sergiu
thanks for your response,
what is the best practice design in this case (l3out FW ha failover ) ,
- two link from each fw to leaf switch using svi  vpc
or
- two link from each fw to leaf switch using routed interface
or
sub interface
As usual, it depends. It depends on your setup / tenant(s) design / routing protocol etc. I would suggest to read the L3Out whitepaper where you will find out about pros vs cons of different l3out designs and you can choose one based on your setup:
https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/guide-c07-743150.html
Stay safe,
Sergiu
Hi Oscar
did this config work. I am working on ACI and F5 which is also active standby. I am not sure about the same IP address for both the active and standby units
