09-14-2016 09:35 AM - edited 03-01-2019 05:02 AM
Hi everyone,
Please see the attached picture for reference. I have 2 questions about this setup:
. When you connect a pair of Leaves to the external network and it requires 4 10G connections, in each Leaf, do you crosspatch from each Leaf to the upstream switches like in the picture or no crosspatch?
. If crosspatch, how do you configure vPC in ACI? I mean, in NX-OS world, you would create port-channel in each Leaf first then configure vPC under the port-channel interface. How do you do that in ACI? Someone told me you would configure a single vPC Interface policy group and add the 4 interface to it. Just want to clarify.
Thanks.
09-14-2016 10:51 AM
Apache_le,
Thanks for posting in the support forums. Please see inline.
If by 'crosspatch', you mean full-mesh, then yes this would be appropriate.
aci-leaf-1 <> standalone-1
aci-leaf-2 <> standalone-1
aci-leaf-1 <> standalone-2
aci-leaf-2 <> standalone-2
You would configure 1 VPC policy group and apply this policy group to all interfaces participating in the same back-to-back/double-sided VPC. Just make sure that the VPC domain ID on the standalone devices are different from the ACI VPC domain ID.
09-14-2016 11:10 AM
Thank you for your comment. Yes, crosspatch means full-mesh. So it sounds like we are on the same pace with the ACI configuration piece. The uplink switch(es) are a pair of VSS-enabled switches, FYI.
