Leaf hw replace interface down
peter.lofgren
Community Member
We replaced a leaf and it come up in the fabic. 2 Interface to spine are up.
all my other ports are down.
what could be the answere?
/ Peter
5 Replies 5
Tomas de Leon
Peter,
Can you attach to the console of the replacement leaf and reboot the leaf? Please capture all of the console messages during bootup and attach a text file with the display output.
also, can you login into the leaf and perform the following commands:
cat /mit/sys/summary
show hardware
show inventory
show interface status
Please attach a separate attach text file with the display output.
T.
Hi Tomas
Attached file when console connected ,  your command output and a reboot.
Not!  We replaced C9396PQ  > C93180yc-cx
But all cables are in place and the interface have the same name.
/ Peter
Peter,
leaf03# show interface status
Port Name Status Vlan Duplex Speed Type
Eth1/18 -- disabled trunk full inherit 10Gbase-SR
Eth1/20 -- disabled trunk full inherit 10Gbase-SR
Eth1/33 vipnet disabled trunk full inherit 10Gbase-SR
Eth1/34 f5-inside disabled trunk full inherit 10Gbase-SR
Po1 -- disabled trunk full inherit --
Po2 -- disabled trunk auto 10G --
Po3 -- disabled trunk auto inherit --
Po4 -- disabled trunk full inherit --
Po7 -- disabled trunk full inherit --
Po8 -- disabled trunk full inherit --
the ports appear to be disabled ("blacklisted").  Simply, go to the physical interfaces that are disabled and re-enable them.  This should fix the issue.
Thank you for participating in the Cisco Support Forum for ACI! If you have other questions related to this post, please let us know. If this response answers your questions, please mark this post "answered" and assign a rating to the response(s) provided. This will help notify other viewers that your question(s) is answered and this helps us provide better responses for this and future questions.
Thank you!
T.
No it didn´t help.
This is bug TAC told us.
SR 681045485.
So I´m waiting for a solution from Cisco.
/ Peter
K so what was the solution?
