Loop L2-Migration Legacy FabricPath to ACI
Danny Koenig
Hi Community,
Need your help to solve this issue. I've read many manuals but no way out.
I want to migrate a legacy network running with Cisco Nexus switches and FEXes to ACI Multi-Pod, VLAN by VLAN. For visualization, please see plan below.
BD=EPG=VLAN connected to static ports (VPCs to Legacy N6K-1 and N6K-2). MCP has been disabled for testing purposes regarding STP.
When adding the VPC as static port from Pod 2 to the EPG the loop has been built. Technically correct, but the STP mechanism won't do anything to prevent the loop.
It's not an option to remove the corresponding VLAN from the interconnects between N6K and N5K for redundancy reasons.
The question is: Would MCP do it or is there any different way for a full redundancy if one N6K becomes unavailable?
Thank you very much Cisco Community.
Danny
Danny Koenig
We built this at the end, without any loops, STP nor MCP problems: double-sided VPC between ACI and N6Ks. In case of a failure (Leaf, N6K), all the VLANs will still be available in both worlds.
Thanks for your help! It feels good having a community like Cisco. Take care!
Danny
6 Replies 6
balaji.bandi
If you are migrating Classic Ethernet to Fabric.
So my suggestion is to extend the VLAN across the Fabric, and you only choose one of  the patches and allow the VLAN to reach the Fabric (can you also keep the configuration on the other side, in case a disaster happens, to bring the Layer 2 connection on the other side of the network)
N6K1 to POD1 for all VLANs allowed
That means all the traffic goes via POD1 until the Migration is finished.
If you like to use both PODs, then only allow the VLAN on the respective POD.
Example :
N6K1 to POD1 - even VLAN
N6K2 to POD3 - Odd  VLAN
I hope this makes sense to you. Once all migrations are complete, you can remove the Nexus Classic environment anyway.
BB
hrtendrup
Remember that ACI does not participate in STP. Your port type on the 6ks probably should be shared, not point-to-point. The port then has to transition through the listen phase of STP before forwarding. That should be enough time for STP to propagate through ACI and one of the portchannels on the 6ks should move to blocking.
</$.02>
Danny Koenig
Thanks for your ideas and replies.
What do you guys think about this construct? VPC on side of both the N6K instead of ACI.
I don't think you should use enhanced vPC in this case; I still stand by my previous suggestion.
If Layer 2 is not must, you can use Layer 3 peering with IGP or BGP
BB
hrtendrup
you can only have 2 nodes in a vpc domain (and probably they have to be in the same pod - though I've never tried otherwise). I'm not sure I understand what you're proposing on the upper side of that vpc oval.  I have used back to back vPC as a method to eliminate redundant paths, but I'm not sure how that helps here. You'd still end up with 2 logical paths.
Danny Koenig
Danny
