01-29-2020 05:57 AM
Hello!
I am experimenting with multicast within an ACI fabric, but I cannot seem to get multicast entries to propagate to switches other than the LHR switches.
I have currently configured ACI accordingly:
VRF-TEST
 - BD-MULTICAST
    - EPG-RECEIVE
- EPG-SOURCE
The receive and source EPGs both provide and consume a contract which allows all types of traffic to be past between them.
I have enabled multicast on the VRF level, and "ticked" the checkbox under the BD to be a PIM domain.
L2 Unknown Unicast: Hardware Proxy
L3 Unknown Multicast Flooding: Flood
Multi Destination Flooding: Flood in BD
Pim: Check
I have also attached a subnet to the BD with the IP address range of the sources.
But whenever I type the command
show ip mroute vrf TEST:VRF-TEST
I only see the multicast routing entries for receivers and senders which are directly connected to said leaf. Is there anyway that I can propagate this multicast routing information to other switches within the ACI fabric? Do I need to enable Fabric RP or anything likewise?
Best Regards
Solved! Go to Solution.
01-29-2020 04:54 PM
to have multicast between VRFs you need to have sender and receive VRFs to be on the same leaf. In other words, on the leaf with subscriber you need to spin source VRF.
01-29-2020 04:54 PM
01-30-2020 12:15 AM
