Nexus Dashboard Communication with APIC for NDO Operations
dan.laden
Looking to have Nexus Dashboard to be outside a firewall and need to allow rules to allow Nexus Dashboard Orchestrator  to communicate with the OOB APIC IP address.
https://www.cisco.com/c/en/us/td/docs/dcn/nd/2x/deployment/cisco-nexus-dashboard-deployment-guide-211/nd-deploy-overview-21x.html
The ports mentions inband of apic and switch.  Is this focused on network insight or ndo or both or other? Does ND for NDO need kafka and kms access to the fabric?  Does ND for NDO need ssh access to the ACI fabric?
Thank You.
In the doc, the next table is labeled for nexus insights.  Is there a table somewhere for NDO.
Sergiu.Daniluk
Hi @dan.laden
Communication between APICs and MSO (NDO) is only using TCP 80/443 for APIC REST API.
You can use this installation guide for reference: https://www.cisco.com/c/en/us/td/docs/dcn/mso/3x/installation/cisco-aci-multi-site-installation-upgrade-guide-311/mso-deploy-install-overview-31x.html
I know it's for the old standalone MSO, but the communication with APIC doesn't change.
Stay safe,
Sergiu
Sergiu.Daniluk
Hi @dan.laden
Stay safe,
Sergiu
seems to be working with just 443 where you have listed 80/443. is there a particular condition where port 80 is required?
when i look a the pod management access policy...http access is disabled, redirect is disabled.
If you have http enabled on your APIC and you want to use http instead of https to connect MSO to APIC, then I guess that would be the condition when port 80 is used.
dan.laden
 ..deleted...
