Nexus Dashboard Deployment
Rem Markov
Hey everyone!
So I would like to set-up the Nexus Dashboard using an automation rather then manually , but I couldn't manage to find any Ansible modules or python modules for this to work, has anybody trying to perform this? or has a clue how ?
5 Replies 5
Robert Burns
IMO - It's not worth the hassel to invest cycles trying to automate ND setup as it'sa  one-time activity.  You'll spend more cycles trying to get automation working (not even sure its possible for the setup) than quickly running through it manually.
If you're adamant about using Ansible, I can ask around, but I haven't heard of anyone doing this for ND setup to date.
Robert
I'll be glad if can ask around! If it is not possible it also okay, just interested!
Robert Burns
Will do.  I doubt there's any Ansible playbooks for this, but I'm sure this can be done with Python at least.
Stay tuned.
Robert
Any updates about the python way perhaps?
Rem Markov
Thanks a lot Robert! I don't mind using python ! As long as it works !
