optimal way to map IP address to node ID.
Guys, not something extraordinary to meet IPs in the CLI output in ACI you would like to know node-id for, right?
There maybe many addresses per node with inability to traceroute to each from arbitrary place :0)
Is there some unified approach to quickly map IP u've derived from CLI output (f.e. with show bgp l2vpn evpn summ on the spine) to node-id?
0 Replies 0
