Overlapping of same subnet(Application Centric Infrastructure)
otgnwp
We have deployed following set up on ACI
Example:
Tenant A -----> VRF A------> BD 1-----> EPG A, EPG B, EPG C(Production)
Tenant A -----> VRF A------> BD 2-----> EPG D
Now , We have a new requirement to use Same IP of EPG A which is not communicate to anyone under Non Production
Same IP will be use on both Production and Non Production(should communicate only to Specific resource)
What is the Best Practice configuration to achieve above requirement on ACI.
if it is possible, Please share a configuration guide.
Thanks in Advance
 Regards ,
Mohammed Asif
18 Replies 18
Hello Asif,
My answers below:
Q. Can i use existing(Prod_Vrf) below L3 Out for Non-Prod_Vrf?
A. No
Diagram showing non-ACI VRF Deployment:
Hello Ashse,
For Non-Prod Vrf, Can i use existing AAEP and Physical Domain or Do i need to configure New?
Thanks in Advance
Mohammed Asif
Hello Asif,
You have to do new Access Policy configuration including new "External L3 Domain"
AshSe
AshSe
Yes, I second @RedNectar opinion about this book. Its old edition and quite expensive. @otgnwp grab it from RedNectar if you can.
Happy learning!!
