CVR-QSFP28-SFP25G for N9K-C9336C-FX2
tjansen123
Does anyone know if its possible to use the CVR-QSFP28-SFP25G for the N9K-C9336C-FX2 to do 10Gb connections or do I need to use the CVR-QSFP-SFP10G= ?
13 Replies 13
balaji.bandi
if you have 10/25 GB SFP you can do, if you have only 10GB SFP i would suggest to go CVR-QSFP-SFP10G=
BB
Thanks Balaji, will it work with just 10gb or is the CVR-QSFP-SFP10G= as its cheaper ?
yes it's viable both point of view (Compatability and  cost)
BB
Robert Burns
As stated in the other thread, that transceiver is not yet supported on that platform - it will NOT work at 25G, 10G or any speed with the released versions as of today.  Support is coming mid next year.
Robert
Wassim Aouadi
Level 4
Level 4
if you want to achieve 10G connectivity on N9k-C9336C-FX2, CVR-QSFP-SFP10G (with an SFP-10G) is supported according to Cisco Compatibility Matrix.
But your switch needs to meet the minimum OS version, either as an NX-OS or an ACI-based switch.
mccurrba
Level 4
Level 4
Is the cvr-qsfp28-sfp25g coming this year
Robert Burns
Yes CVR-QSFP28-SFP25G support will come in the next NXOS 10.3(3)F release due out this month/early next with support on the 93108TC-FX3P, 9348GC-FXP, 9336C-FX2 and GX2 platforms.
Robert
Any update to the release.  I really need for the cvr to work with my c9336C-FX2.  Equipment only goes up to 25GB and currently needing to burn additional switches for support  for them and then tying into the nexus
Brian
Hang in there Brian, should drop any day. Just going through final regression testing as we speak.
Robert
Hi Robert,
Trying to find spec sheet of this adaptor however I cannot find it anywhere, any idea where to look for it ?
best regards
Do you know if the CVR-QSFP28-SFP25G will be supported in the C9500-48Y4C switches as well?
Michael Cave
I'm running 10.3.3.F on my C9336-FX2 anyone connecting 25GB with a C9300-48P? Which CVR/model was chosen?
C9300-48P  - what uplink Module - check the datasheet
C9300-NM-2Y
Catalyst 9300 Series 2x 25G/10G/1G Network Module
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9300-series-switches/nb-06-cat9300-ser-data-sheet-cte-en.html
BB
