Port-channel as destination for local SPAN on ACI?
Ivan Z.
Hi all,
Any specific reason why a Port-channel cannot be used as destination for local SPAN configuration on ACI?
I need to mirror traffic from a vPC (2x10G) and the only option for local SPAN is to use a single 10G access port as destination. Is my only alternative to use ERSPAN with EPG as destination?
Ivan
micgarc2
PC and vPC cannot be used as a destination port for Local SPAN. Go with ERSPAN.
PatrickH1
Hello Ivan,
which Version are you running?
I think you are using Access Span, right?
What is the purpose of the SPAN monitoring or troubleshooting?
Do you expect 20 Gig in total?
Kind Regards
Patrick
Hi PatrickH1,
It is not about the version, I tried both 2.x and 3.x... it is simply not supported.
Ivan
micgarc2
Hi micgarc,
Yes, it seems like the only way to go. Thanks!
Ivan
