Port channel 'not deployed'--any ideas?
aswokei
I did everything I think I need to do, but I'm getting this error when I create a port channel.
 Here's the fault.
Fault delegate: Configuration failed due to invalid-card,invalid-port for uni/infra/accportprof-Leaf101-102_prof/hports-pSel51-54-typ-range for node Leaf1
Details
I’ve tried looking into the forums, as well as googling.
I don’t know what this could mean.  ‘invalid-card,invalid-port’?  The interfaces are up.
Eth1/48        --                  connected  trunk      full     10G      10Gbase-SR
Eth1/49        --                  connected  routed     full     40G      QSFP-H40G-AOC5M
Eth1/49.10     --                  connected  routed     full     40G      QSFP-H40G-AOC5M
Eth1/50        --                  sfpabsent  routed     full     inherit  --
Eth1/50.2      --                  parentdown routed     full     inherit  --
Eth1/51        --                  connected  routed     full     40G      QSFP-40G-SR4
Eth1/51.3      --                  connected  routed     full     40G      QSFP-40G-SR4
Eth1/52        --                  notconnect routed     full     inherit  QSFP-40G-SR4
Eth1/52.4      --                  parentdown routed     full     inherit  QSFP-40G-SR4
Eth1/53        --                  connected  routed     full     40G      QSFP-40G-SR4
Eth1/53.5      --                  connected  routed     full     40G      QSFP-40G-SR4
Eth1/54        --                  notconnect routed     full     inherit  QSFP-40G-SR4
Eth1/54.6      --                  parentdown routed     full     inherit  QSFP-40G-SR4
Cannot for the life of me figure out what this means. Any ideas would be greatly appreciated.
gmonroy
aswokei,
    Depending on your model of switch, the upper 6-12 ports are Fabric Ports which means they are only meant to be connected into spines and not configured for host connectivity.
From the ACI Fabric Hardware Installation Guide:
Connecting Leaf Switches to Spine Switches
For optimal forwarding between endpoints, you must connect each leaf switch (Cisco Nexus 93108TC-EX, 93108TC-FX, 93120TX, 93128TX, 93180LC-EX, 93180YC-EX, 93180YC-FX, 9332PQ, 9372PX, 9372PX-E, 9372TX, 9372TX-E, 9396PX, or 9396TX) to every spine switch (Cisco Nexus 9336PQ, 9504, 9508, or 9516) in the same ACI fabric. The following table lists the number of ports that you can connect on each type of leaf switch and the supported speeds for those ports.
Leaf Switch
Maximum Number of Uplink Connections
Supported Transmission Speeds (Uplink Ports)
6 QSFP28 fixed ports
10, 40, and 100 Gigabits1
Cisco Nexus 93108TC-FX
Cisco Nexus 93120TX
6 QSFP+ fixed ports
40 Gigabits
Cisco Nexus 93128TX
with M6PQ or M4PQ-E uplink module
6 QSFP+ ports
40 Gigabits
with M12PQ uplink module
8 QSFP+ ports (leftmost 8 ports are supported on 12-port module)
1, 10, or 40 Gigabits1
Cisco Nexus 93180LC-EX
Cisco Nexus 93180YC-EX
Cisco Nexus 93180YC-FX
Cisco Nexus 9332PQ
6 QSFP+ fixed ports
10 or 40 Gigabits1
Cisco Nexus 9372PX
Cisco Nexus 9372PX-E
Cisco Nexus 9372TX
Cisco Nexus 9372TX-E
6 QSFP+ ports
40 Gigabits
Cisco Nexus 9396PX
Cisco Nexus 9396TX
6 QSFP+ ports
40 Gigabits
12 QSFP+ ports
10 or 40 Gigabits1
1 For 10-Gigabit support, use a QSFP-to-SFP adapter (such as CVR-QSFP-SFP10G) with a SFP+ or SFP transceiver.
The overview section of the same guide goes into model specific port usage.
-Gabriel
Fantastic.   I even recall reading that in a book.  Just forgot. Thanks!
Support for converting the uplinks to downlinks was added in 3.1(1i) with EX or FX model switches.
APIC 3.1(1i) Release Notes # Search for Converting uplink ports and downlink ports
You can connect a FEX to those interfaces now.
