PYATS error in learning features on a NXOS device in ACI mode
rdefreitas
I was hoping someone can give me some insight into this PYATS error when trying to learn "interfaces" on a NXOS switch running in ACI mode. If I issue the command "pyats learn interface --testbed-file testbed.yml" I get this error message listed below. Is PYATS able to learn or parse ACI configurations from the APIC itself or do I need to use this tool against the NXOS switch running in ACI mode only?
Learning '['interface']' on devices '['nexus-test-sw-01']'
Connecting to 'nexus-test-sw-01' with alias 'rest'
<Response [200]>
Connected successfully to 'nexus-test-sw-01'
0%| | 0/1 [00:00<?, ?it/s]Caught error while executing target in child process-0:
target = _retrieve_ops
args = (<Device nexus-test-sw-01 at 0x7f47a65a5fc0>, 'interface', '.')
kwargs = {}
Traceback (most recent call last):
File "src/pyats/async_/parallelcall.py", line 90, in pyats.async_.parallelcall.ChildLabor.run
File "src/genie/cli/commands/learn.py", line 338, in genie.cli.commands.learn.LearnCommand._retrieve_ops
File "src/pyats/topology/device.py", line 559, in pyats.topology.device.Device.__getattr__
AttributeError: 'Device' object has no attribute 'log'
My testbed file:
testbed:
credentials:
default:
username: admin
password: XXXXXXXXXX
devices:
nexus-test-sw-01:
os: nxos
platform: apic
custom:
abstraction:
order: [os]
connections:
rest:
class: rest.connector.Rest
ip: 10.XX.XX.XX
Greg Gibbs
This board's focus is mainly around Cisco Identity Services Engine (ISE) and AAA. This question would be better suited for the ACI board.
https://community.cisco.com/t5/application-centric-infrastructure/bd-p/12206936-discussions-aci
