How to check route using rest api call
Prakin
hi,
how to check specific routes using rest api call?. which could be similar to "show ip route x.x.x.x vrf all"
balaji.bandi
Depends on what Router and IOS code running on it. check below guide for reference :
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/restapi/restapi/RESTAPIvrf.html#pgfId-1076852
BB
Prakin
thanks, well actually i am looking for ACI, where are the routes can be fetched from APIC
mabushei
in Cisco ACI the rest APIs is constructed using the structure of the object model and REST API conventions.
The below API call is constructed using the structure of the object model, with each part of the object model represented in the URL of the API call.
GET https://<APIC_IP_ADDRESS>/api/mo/uni/tn-<TENANT_NAME>/out-<VRF_NAME>/rt-[<NETWORK_ADDRESS>/<PREFIX_LENGTH>].json
For example, in the API call, uni represents the root of the object model, tn-<TENANT_NAME> represents the tenant, out-<VRF_NAME> represents the VRF, and rt-[<NETWORK_ADDRESS>/<PREFIX_LENGTH>] represents the specific route. By following this structure, the API call is able to retrieve the desired information about the specific route.
Cisco ACI Object Model Reference Guide. This guide provides a comprehensive overview of the object model and the structure of each object, as well as the relationships between objects.
ecsnnsls
You can poll the fvCEp, uribv4Route, uribv4Nexthop, uribv6Route and uribv6Nexthop classes to retrieve the routes.
