Refreshing APIC-L2's with APIC-L4's
vv0bbLeS
Hello all,
I'm trying to make sure I understand the procedure for refreshing our current L2 APIC's with our new L4 APIC's.
Currently our fabric is running 5.2(4) , and the new L4 APIC's require either 5.3 or 6.0.5 (which has just come out and is what we want to use).
My understanding is I need to upgrade the existing L2 APIC's to the new software version (in our case 6.0.5), and then I can just perform the "APIC replacement" procedure one-by-one?
  • Or is it possible to not have to upgrade our existing L2 APIC's (leave them running 5.2(4) ), and then replace each L2 APIC with a new L4 APIC that would be running 6.0.5 ? I feel like this is a bad idea though : )
0xD2A6762E
Robert Burns
APICs in a Cluster must be all the same version.  Upgrade the existing L2 APICs to an L4-APIC supported version (5.3 or 6.0), then follow the regular replacement providure one by one.
Robert
mannytavarez
Following as I have to do the same
Robert Burns
Robert
vv0bbLeS
@Robert Burns great! Thanks again!
0xD2A6762E
