Single APIC Firmware Upgrade.
I have a requirement to upgrade Single APIC firmware without connecting it to the ACI fabric.
I got new APIC from the cisco (RMA one) and its existing firmware is lower that the current ACI fabric firmware. So i want to know how do i upgrade the APIC without connecting it to the ACI Fabric.
I just want to Upgrade the APIC and Need to add it the ACI fabric after upgrading it.  Please provide information / Link or helpfull videos regards of this
Thank you !
Marcel Zehnder
You need to mount/install the APIC-ISO via CIMC.
Marcel
Please raise cisco TAC,which will ease for upgrade your apic controller because the easiest method is to upgrade via CLI from other apic controller.
Moreover,there are other methods but you have to follow lot of steps,it would be time consuming and complex.
