SSH Access to Leaf and Spine Switches
maced129
I am having trouble getting access to the CLI of the leaf and spine switches of my ACI fabric. I know you can perform show commands via the apic fabric command set but I am looking to execute the contract_parser.py script on the leafs to troubleshoot contracts and check out the viability of the tool that is supposedly included in the ACI image 3.2+ . Any login that I used I recieve a permission denied in the event log. APIC locally configured users and LDAP users aren't working. Any ideas or tips on how to tshoot?
(Source for contract_parser info: https://github.com/agccie/aci-contract-parser)
Hi Alexander,
I was finally able to get it working - it turns out it was infact due to
the leaf switches OOB/INB connectivity not yet being set up properly.
Viewing the command "fabric XXX show aaa authentication" command on the
APIC I was able to see that the leafs were preferring an LDAP
authentication method - they do not yet have a route to those servers via
OOB/INB communication channels. Through Admin > Authentication config
section on the APIC GUI I set the login to "Local" instead of LDAP, waited
for the configuration to propagate to the leafs and I was able to get into
the leafs and execute the parser script!
Thanks for all your help!!
7 Replies 7
Alexander09
Can you login to your apic via ssh and once you logged in, can you perform <<show switch>> and try to perform the following command <<attach leafname>> ?
Also verify if ssh is enabled as mgmt access through the gui -> Fabric > Fabric Policies > Policies > Pod > Management Access ?
cheers
Alexander
Alexander Deca
Thanks for the reply. The command executes and SSH command to the leaf but it still has a login prompt which none of my login credentials work for. SSH is enabled in the management access in fabric policies.
Could this have something to do with the leafs OOB/INB mgmt connectivty for LDAP auth (my current primary auth method) or something?
You can specify the domain during ssh << ssh -l apic#fallback\\admin 10.10.10.1 >>, this will use local authentication.
cheers
Alexander Deca
Sorry for the delay,
Unfortunately no luck with that command. It must be something to do with
the OOB/INB connectivity and configuration.
On the APIC can you paste the output of <> ? And have you verified the gui, paste a screenshot of this as well ? (Fabric > Fabric Policies > Policies > Pod > Management Access)
Did you try to use the username rescue-user with no password (or with the initial password you have set when running the setup script on the APIC) ?
Alexander Deca
Hi Alexander,
Even though you should always be able to login with the <<ssh -l apic#fallback\\admin >> command if the leafs have been provisioned correctly or through the gui with username << apic:fallback\\admin >>.
But glad you have sorted it out!
Alexander Deca
