Terminal monitor command ACI
lAhmed Saadl
Hello Team,
Is there an equivalent command for terminal monitor, show logging on Leaf SWs?
7 Replies 7
AshSe
In Cisco ACI to view logs, use the command: show logging
Below are two syntax options that can be used after logging
ip   onboard
lAhmed Saadl
I got those AshSe, I am just asking about if there is similar command of the traditional network output of (terminal monitor and show logging) to check the live changes in a real time.
@lAhmed Saadl I didn't get what you are looking for.
RedNectar
Hi @lAhmed Saadl ,
I can answer your question with a single word
NO.
(Sorry about that)
I guess the ACI philosophy is that all monitoring should be via the APIC.  But a console message indicating when an interface goes up or down could be really useful.
BTW - this question was asked before in 2018 and has zero replies!
 https://community.cisco.com/t5/application-centric-infrastructure/aci-cli-how-to-display-events-in-real-time-terminal-monitor/m-p/3332492
Nothing is going to happen on a switch unless it has been initiated by the APIC,
RedNectar aka Chris Welsh.
what if I want to know if an interface does change its status?
There will be a fault and/or event in the APIC.
u can use linux commands e.g "watch show interface ethernet 1/1"
