08-07-2024 09:24 AM
Hello Team,
Is there an equivalent command for terminal monitor, show logging on Leaf SWs?
08-07-2024 11:13 PM
In Cisco ACI to view logs, use the command: show logging
Below are two syntax options that can be used after logging
ip onboard
08-08-2024 01:42 PM
I got those AshSe, I am just asking about if there is similar command of the traditional network output of (terminal monitor and show logging) to check the live changes in a real time.
08-08-2024 08:37 PM - edited 08-08-2024 08:37 PM
@lAhmed Saadl I didn't get what you are looking for.
08-08-2024 09:33 PM
Hi @lAhmed Saadl ,
I can answer your question with a single word
NO.
(Sorry about that)
I guess the ACI philosophy is that all monitoring should be via the APIC. But a console message indicating when an interface goes up or down could be really useful.
BTW - this question was asked before in 2018 and has zero replies!
Nothing is going to happen on a switch unless it has been initiated by the APIC,
07-24-2025 04:34 AM
what if I want to know if an interface does change its status?
07-24-2025 07:07 AM
There will be a fault and/or event in the APIC.
