Transit routing and VRF leaking between two L3Outs
Daniel S.
Hello ACI people,
I came across interesting scenario.
I need to create Transit Routing between two different L3Outs, L3Out-A and L3Out-B, they are in different VRFs, VRF-A and VRF-B under one Tenant.
L3Out-A is using OSPF and L3Out-B is just a static route.
I am attaching the diagram to explain what has been configured as far as flags on the external subnets.
After configuring all the mentioned points on the diagram, I finished up with a contract with a global scope.
Once finished, I have seen the routes properly leaked between VRFs.
Then I realized, that this is no good and does not work.
I did ELAM capture and I see "SECURITY_GROUP_DENY".
Which indicates absence of a contract allowing communication between the source and destination EPGs, but I do have a contract in place.
What am I doing wrong?
Sadly at this Fabric I am running 4.2n release.
Thank you in advance :).
Daniel S.
Small update.
The initial Contract was created in the same Tenant where I have both L3Outs. After I created a new identical Contract in the Common Tenant, then the Contract was applied and packet forwarded. Waiting for a confirmation to see if this works, but seems like this helped.
