Transit routing - L3out with static route
hichamfolk
Dear Community,
We have some servers behind router who acts as gateway, this router will be connected to ACI Leaf switch with l3out STATIC ROUTE. And to communicate with externe networks, we have another existing l3out with ebgp via Border LEAF (used to receive default route on BLF).
Now to announce servers subnet to legacy, we will use 'Export route control subnet' with 0.0.0.0/0 subnet and 'Aggregate Export' options.
1- Is it enough as configurations or do we need to do something else ? Specially some Leaking/redistribution of servers network to BGP (like what we do in legacy routers with 'network X.X.X.X' command under bgp process) ?
2- There is another way to enable transit routing for l3out with static routes without using 'Export route control subnet' option ?
Kind Regards
Hicham
follow
Aleksandr Ismagilov
Hi Hicham,
1. The "Export route control subnet" flag is used for an outbound route control on an L3Out - that is, it ultimately configures an outbound route-map on the L3Out to control the outbound route advertisements.
It doesn't configure a transit routing on its own, but in your scenario, some sort of export route control (done in one way or another) is required as BGP L3Out has export route control hard-enabled.
In addition to this, you need to configure a contract b/w the "server's" L3Out EPG and BGP L3Out EPG to both allow the traffic to pass and the prefixes to be exchanged b/w the two L3Outs.
As you need this contract, your L3Out EPGs should be configured appropriately (i.e., have subnets with External Subnet for External EPG flag configured - I assume yours is an intra-VRF use case).
The static route is automatically redistributed into BGP IPv4 Unicast when it's configured, so there's not need to perform any additional steps for this. However, you can control this redistribution using a Route profile, if so desired.
2. To enable transit routing b/w you always need a contract. However, the route control can be achieved in different ways.
Check out the L3out guide - it's very good and covers what you need to know:
https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/guide-c07-743150.html#L3OutTransitRouting
