01-04-2015 05:45 PM - edited 03-01-2019 04:47 AM
Hi guys,
Just to straighten my understanding of APIC and APIC-EM within the ACI initiative.
From the various Cisco and general resources, I am under the impression that the APIC's and APIC-EM's southbound leverages OpenFlow and OnePK to talk to a wide range of devices.
If so, ACI southbound should be able to a select range of legacy devices.
Since the APIC hardware already houses the code of the "brain", including northbound REST and southbound protocols,
Many thanks
Solved! Go to Solution.
01-05-2015 04:44 AM
A very simple answer to both of your questions is that the n9k is the only Cisco switch that understands the policy model that the APIC uses, this is in part due to the firmware image that the switches run which is very different from standard NX-OS. Also, the Cisco Application Leaf Engine(proprietary ASIC) in the GEM on the leaf switches understands and makes forwarding decisions based on that policy.
Thanks for using ACI support forums! hope this helps.
01-05-2015 04:44 AM
