ACI grep for either/or
vv0bbLeS
Level 7
Level 7
Hello all,
I am trying to use grep to return multiple lines that may match different things (i.e. either/or). For example, say I have the following output on an APIC:
Node201
Node202
Node203
I would like to have grep return lines with EITHER "201" OR "202" in the line, so for the above output, I would like to have grep return:
Node201
Node202
I have tried using the | symbol and also regex grouping like so, but with no luck:
grep "201|202"
grep "(201|202)"
I have also tried grep -e as well as extended grep, also with no luck.
Does anyone know how I would return lines from output that matches multiple criteria in an either/or fashion?
0xD2A6762E
RedNectar
Hi @vv0bbLeS ,
try using egrep (or grep -e)
So you type
command egrep "20[12]"
I hope this helps
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
RedNectar aka Chris Welsh.
RedNectar
Hi @vv0bbLeS ,
So you type
I hope this helps
Wow DUH I didn't even think about using character classes lol, that works perfectly! And i also tried it with regular grep and it also works with that. Thanks again!
0xD2A6762E
