07-28-2017 09:09 PM - edited 03-01-2019 05:18 AM
H Guys,
How can I use ACI to be a transit for Layer 2 traffic in migration scenario? Can the same EPG L2OUT be on two different leaf switches, if so does the traffic transits the ACI ( getting to ACI from one end and going out to the other side)
Hamed
Solved! Go to Solution.
07-28-2017 11:02 PM
Hi Hamed,
Very simple answer - Yes!
But in more detail:
You can simply map VLAN IDs to Application EPGs, or, as you suggested, map VLANs to L2 Out EPGs (Bridged Outside Networks)
Can the same EPG L2OUT be on two different leaf switches, if so does the traffic transits the ACI (getting to ACI from one end and going out to the other side)
Yes. You no matter which method you use, you will need to map VLANs on particular ports on each leaf switch. Once that is done, traffic within VLANs/EPGs will be flowing.
Just remember that if you are connecting both leaf switches to external switches:
I hope this helps
RedNectar
aka Chris Welsh
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
07-28-2017 11:02 PM
Hi Hamed,
But in more detail:
I hope this helps
RedNectar
aka Chris Welsh
