Communication Between Cisco Switch with 1GbE SFP and Juniper Switch with FE SFP
nabeelcse07
I have a scenario where there is Cisco Switch at one side and Juniper Switch at another side. Juniper Switch is equipped with FE SFP and Cisco Switch with GbE SFP. Is communication possible between two switches?
dpita
Hello
You posted this question in the ACI support forum, are you connecting the Cisco switch and the Juniper switch to ACI?
Regarding your question if they are directly connected, I would think it would work assuming the Cisco switch can run at FE (100mb) speeds, otherwise i don't think it will work as there would be a speed mismatch on the link.
