08-03-2017 11:21 PM - edited 03-01-2019 05:18 AM
Dear All ,
08-06-2017 01:02 AM
Dear All ,
Please help me on this case .What is the process to configure Single cluster using 5 Node APIC controller and what would be physical connectivity to make single cluster between two sites.
It would be highly appreciate if you reply using physical connectivity between two sites .
I am eagerly waiting for your reply .
With regards
Erfan
08-06-2017 01:44 PM
Hi Erfan,
Have you explored to see if the ASRs will support the ACI Multipod solution? I had a quick look at the ACI Multipod solution, but it doesn't mention ASR, so you might need to ask that question specifically.
Regarding OOB management, again I'd recommend using inband management instead, but if you must use OOB then my answer to your other question should work across a multi-pod fabric, but of course requires the fabric to be operational to maintain connectivity.
I'd advise that you have separate OOB management networks at each site, and if OOB connectivity is required between sites when the Inter-Pod connectivity is down, you'd need to connect the OOB networks some alternative way, possibly a VPN tunnel over a public network.
I hope this helps
RedNectar
aka Chris Welsh
Don't forget to mark answers as correct if it solves your problem. This helps others find the correct answer if they search for the same problem
08-07-2017 08:07 PM
Dear All ,
Please suggest me whether we can configure Multi-POD technology between DC and NDC .I have noticed in some documents where they said that we need 40G connectivity between Spine and IPN device (Layer 3 device ) .But client does not have 40G in ASR router .As per the attached documents , Multi-POD support 10G but Spine Switch(N9K-C9336PQ) does not support 10G connectivity with IPN devices .
Please find the attach consideration for Muti-POD scenario .
Considering the above situation , I need to configure stretch fabric between two sites .Please give your valuable inputs ,how I can configure stretch fabric as I do not have any other option to create muti-pod scenario .
Please advise me how I can configure stretch Fabric between two sites .I have seen some documents that I need to create EOMPLS circuit .
What is the configuration to create EOMPLS circuit between two sites and discover the all components as I have 8 leaf , 2 Spine and 3 Nodes APIC in each site and 8 leaf , 2 Spine and 2 Nodes APIC in other site .
Can you tell ,what would be the procedure to make single cluster first time between two sites .
with regards
Erfan
08-09-2017 11:15 AM
Hi Welsh ,
I need your valuable comments and waiting for your reply .
With regards
Erfan
08-09-2017 01:21 PM
Erfan,
I am so angry with this site - I just spent almost an hour answering your question and then the site lost it when I posted it!
Basically I said:
So therefore your #1 problem is to step 40G down to 10G
Once you have solved #1 problem, I would advise using ACI Multi-pod, with 2 APICs in the main site and 1 APIC in the other. Configure your remaining two APICs in standby, one in each site.
Alternatively, you could buy one more APIC for the second site and run two independent sites, in which case you could connect the leaf switches from one site to the other using a L2 connection, which if you really wanted it, could be EoMPLS - but any L2 tunnel/direct connection would do.
You might get some more ideas from BRKACI-2125 - ACI Multi-Site Architecture and Deployment (2017 Las Vegas) and BRKACI-2003 - Cisco ACI Multi-Pod Design and Deployment (2017 Las Vegas)
I hope this helps
RedNectar
aka Chris Welsh
08-12-2017 01:48 AM
Hi Welsh ,
Sorry for late reply .
I got your your points to make multi-pod or stretch Fabric .
Please give me some inputs whether I can make multi-pod or stretch Fabric connecting leaf switch N9K-C9396PX with ASR 1002 Router with 10G connectivity instead of 9336-PQ spine switches with ASR 1002 Router as I do not have 40G connectivity in my ASR Router to connect Spine for Multi-pod or stretch Fabric .
My intention is to connect Two ASR router with L3 connectivity and configure EOMPLS circuit between two sites .So I am trying to connect leaf of each switch would be connected with each ASR router with 10G connectivity in each site.
Please suggests whether above topology would be possible or not .
Your valuable inputs is highly appreciated .
08-07-2017 07:10 AM
Hello Erfan,
is there a special requirement why you want to use a stretched fabric design rather than Multi-Pod? Multi-Pod is very well documented in the white paper (https://www.cisco.com/c/en/us/solutions/collateral/data-center-virtualization/application-centric-infrastructure/white-paper-c11-737855.html) and other configuration guides. It will give you the active / active behavior you want and you can connect your DC sites via routing. An Inter-Pod Network is required but the ASR 1k and 9k should be able to provide all functionality needed (PIM-Bidir, DHCP relay, MTU of 9150 and OSPF).
For the discovery, that works over the IPN as well. Basically you install and cable all your components where they should be and start discovery in your main data center. Once a spine connected to the IPN is discovered it will discover a spine in the remote DC and from there go down to leaf switches and APICs. Doesn't matter if you use 3 or 5 APICs. Also it happens via the infrastructure IP network and is not affected by how you manage your switches.
I'm not sure if I got your questions all right but I answered to what I understood. Feel free to clarify if I missed something.
Nik
