Rapid7 showing RedHat vulnerabilities when scanning ACI Nodes
a.bernardes
Hello guys, my 1st discussion here
The company that I work for uses Rapid7 to scan vulnerabilities through devices.
The report is saying that a specific one is found at my ACI nodes (Apics, Spines and Leaves)
That's the vulnerability description:
"lilo-linux-single-user-mode"
That's the details:
"Refer to this documentation (https://access.redhat.com/solutions/1987833 ) from RedHat for exact details on enabling authorization for single user mode in RHEL7."
I know that the Apic software is RHEL/CentOS based, so I've checked at RedHat page trying to understand the issue:
"How to password-protect single user mode in RHEL 7 with /etc/inittab
 SOLUTION VERIFIED - Updated October 20 2015 at 5:50 PM -
Environment
  • Red Hat Enterprise Linux 7
Issue
  • How to password-protect single user mode in RHEL7?
  • How to enforce a password for the single user mode?
  • How to prevent user from getting into single-user mode or runlevel 1 without a password?
  • How to set the ":S:wait:/sbin/sulogin" in RHEL7?
Resolution
  • RHEL 7 single user mode is password protected by the root password by default as part of the design of grub2 and systemd
  • /etc/inittab is no longer in use with systemd
  • Set up a different password for grub2 than the standard root password
But we don't have access (and I understand why) to change this at APIC or the other nodes.
Does anyone know if there is any caveat or workaround over this issue?
ACI Version is 3.2.9h
0 Replies 0
