Replacement of ACL with ACI Contracts
faizal_vi
I have a scenario where I need to configure the below kind of ACL in ACI. How is possible to achieve it using contracts?
172.16.2.0/24=BD2 <<<VLAN2_EPG>>>
172.16.3.0/24=BD3 <<<VLAN3_EPG>>>
Currently I have the default contract applied.
SRV01=172.16.2.11
SRV02=172.16.2.12
SRV03=172.16.3.11
SRV04=172.16.3.12
If need to create contract based on the host, how is it possible to achieve.
Please note that this an example. My setup is much bigger where I have a requirement to create such kind policies using multiple end hosts
Sergiu.Daniluk
Hi @faizal_vi
Contracts in ACI do not use IP for filtering. The filter entry in a contract is a rule that allows or denies traffic that is classified based on TCP/IP header fields, such as Layer 3 protocol type or Layer 4 ports.
If you have specific requirements between specific IP addresses, you can group the servers in dedicated uEPG and apply contracts on/between the specific uEPGs:
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/4-x/virtualization/Cisco-ACI-Virtualization-Guide-42x/Cisco-ACI-Virtualization-Guide-421_chapter_0100.html
Sergiu
Is it possible for an endpoint to be a member of multiple uSeg EPGs?
I am still thinking from the ACL perspective where in we can call multiple acls from hosts/ network (source)to different hosts/ networks (Destination)
No, you cannot have an EP in multiple uEPGs.  However, you can configure multiple contracts on a single uEPG.
Stay safe,
Sergiu
