Right way to delete objects in ACI
Johannes Luther
Level 4
Level 4
HI ACI pro's,
According to the REST API guide, there are two ways to delete an object in ACI:
- HTTP DELETE operation (no examples given)
- HTTP POST operation, referencing the object DN with the attribute "status":"deleted"
What is the most common and correct way? Or or both methods equally valid?
2 Accepted Solutions
Robert Burns
Depending on the version, both methods will work.  On earlier version, only the post method was supported with the status property change.
Robert
Marcel Zehnder
Hi Johannes
From my point of view, the easiest way is sending a HTTP DELETE to the DN of the object.
For example: Delete EPG "WEB1" under application profile "PROD" in tenant "XYZ":
DELETE https://<APIC>/api/mo/uni/tn-XYZ/ap-PROD/epg-WEB1.json
Marcel
Robert Burns
Robert
Marcel Zehnder
Hi Johannes
Marcel
