SSH to apic using Domain
zulfikhar_a
Frequent Visitor
Frequent Visitor
Any idea how to perform ssh to apic using Domain (Not DefaultAuth).
Example: Username: user1, Domain: MS
I tried this way, which didnt help.
MS\zamanull@<apic>
apic:MS\\zamanull@<apic>
Zulfi
6askorobogatov
Level 5
Level 5
apic#POLICY-NAME\\username
Policy name is case sensitive.
This is not working…I tried this on a terminal: apic#POLICY-NAME\\username
Note: POLICY-NAME is MS
I gave $ ssh apic#MS\\[email protected]
It is working. You need to go to APIC GUI, in the 3rd line "Domain" you should have more then one profile,  first one will be DefaultAuth, 2nd one is your AD/LDAP profile. If  the name  of this profile is "MS"and you can login to GUI with this profile, your UID and PWD, then  "  apic#MS\\zulfi "  should work as well as apic#fallback\\UID for default authentication.  If it is not working, then profile / username /password are incorrect or ssh to apic is not permitted.
