SSH to apic using Domain
zulfikhar_a
Any idea how to perform ssh to apic using Domain (Not DefaultAuth).
Example: Username: user1, Domain: MS
I tried this way, which didnt help.
MS\zamanull@<apic>
apic:MS\\zamanull@<apic>
Zulfi
6askorobogatov
apic#POLICY-NAME\\username
Policy name is case sensitive.
This is not working…I tried this on a terminal: apic#POLICY-NAME\\username
Note: POLICY-NAME is MS
I gave $ ssh apic#MS\\zulfi@10.10.10.100
It is working. You need to go to APIC GUI, in the 3rd line "Domain" you should have more then one profile,  first one will be DefaultAuth, 2nd one is your AD/LDAP profile. If  the name  of this profile is "MS"and you can login to GUI with this profile, your UID and PWD, then  "  apic#MS\\zulfi "  should work as well as apic#fallback\\UID for default authentication.  If it is not working, then profile / username /password are incorrect or ssh to apic is not permitted.
