Calisti Installation Error
philiwon
I tried to follow the guide to install Calisti on my k8s cluster (1.22.12) with 2 nodes (1 master and 1 slave).  As you can see below, the installation stopped at the following point...(in verbose mode). Any guidance on how to resolve this is much appreciated. thanks.
regards
Phil.
smm/wait/readiness ❯ pending name=smm-federation-gateway, namespace=smm-system, apiVersion=apps/v1, kind=Deployment
Error with stack:
timed out waiting for the condition
wwwin-github.cisco.com/cisco-app-networking/smm/pkg/common/operator/reconciler.(*Dispatcher).Handle
/mnt/workspace/N_backyards_backyards_smm_v1.9.1/clean_state_for_goreleaser/pkg/common/operator/reconciler/component.go:160
wwwin-github.cisco.com/cisco-app-networking/smm/pkg/common/operator/reconciler.(*Dispatcher).Reconcile
/mnt/workspace/N_backyards_backyards_smm_v1.9.1/clean_state_for_goreleaser/pkg/common/operator/reconciler/component.go:91
wwwin-github.cisco.com/cisco-app-networking/smm/services/cli/internal/deploy.ReconcileRequestWithRetry.func1
/mnt/workspace/N_backyards_backyards_smm_v1.9.1/clean_state_for_goreleaser/services/cli/internal/deploy/reconcile.go:29
7 Replies 7
Geevarghese Cheria
Hi Phil,
   Are you following this documentation https://smm-docs.eticloud.io/docs/quickstart/ and using Free tier for the installation ? I think we need one master and 2 worker nodes. Please let us know on which platform have you created the k8s cluster and trying for the Calisti installation. https://calisti.app/
Thanks and Regards,
Geevarghese
Thanks for replying. I tried both CentOS and Ubuntu (1 master plus 2 slaves version 1.21 and 1.22). Error is the same. it aborted at the same point mentioned on the original post. kind of "time out waiting...". I am behind a proxy but i have coded correctly and all pulling images of containerd works ok. all nodes are with 16 vCPUs, 32GB RAM and 100GB disk. any further clue? thanks.
Did you check on the cluster see any pod issue ?
Can you please also attach entire installation log ? Today I got the "Error with stack:
timed out waiting for the condition..." like to see if the same as yours
yawming
Which SMM binary you downloaded? Mac or Linux ?
First thing may want to check if the resource meet the min request.
https://calisti.app/quickstart - Prerequisites
Also check your cluster
"kubectl get pods -A" see if smm created pods are running ok
tiswanso
Hi Phil,
Thanks for trying Calisti!  My initial suspicion is that this sounds like it matches symptoms seen when the cluster-name auto-learned by SMM does not comply to Istio resource naming validation ("_" or "." or ":" characters).  On the cluster you could check this via "kubectl get clusters" to get the name of the cluster object.  If that's the case you should:
smm uninstall -a
CLUSNM=$(kubectl get clusters -o jsonpath='{.items[0].metadata.name}')
kubectl delete cluster $CLUSNM
smm install -a --cluster-name <any compliant name>
https://smm-docs.eticloud.io/docs/installation/single-cluster-setup/#install-hahahugoshortcode-s1-hbhb
(edit -- fixed the link to the external URL)
philiwon
Thanks all for your advice. Finally figured out that my lab is behind a proxy; i need to disable the proxy before the kubeadm init. Now Calisti is up and running.
