11503 and SSL Termination - Cookie Handling
aarons444
I'm looking for some insight on how the 11503 handles SSL termination,
specifically with regard to cookie handling. We are going to be
installing a 11503, so it can handle load balancing, content switching
and SSL termination instead of IIS / WLBS. If you move SSL termination
off of the Web servers and disable SSL in IIS, how does ASP.NET handle
secure cookies? We want to set requireSSL="true" in Web.config, but
since the Web server will no longer be running SSL, it won't enforce
that attribute. I was wondering if the content switch passed any
special header to IIS, or if the content switch can be configured to
add the secure attribute to all cookies. I haven't found anything in
the documentation so far.
Depending on your software version, this page has links to CSS SSL configuration Guides based upon the software you're running.
http://www.cisco.com/en/US/customer/products/hw/contnetw/ps792/products_installation_and_configuration_guides_list.html
You can configure the CSS to issue cookies in place of the actual server.
