11503 Loadbalance SSL sticky and HTTP not sticky to proxy-cache
support
I am using a 11503 to balance 200 schools traffic to 5 caches. Some of the schools have firewalls so the CSS sees their PCs as coming from a single IP. If I set the rule to balance sticky then the load is not spread evenly to the 5 proxies causing them to get overloaded from time to time.
If I balance the load non-sticky (say leastconn) then users have trouble accessing certain SSL sites.
Does anyone know a good solution for this?
9 Replies 9
jfoerster
Level 4
Level 4
HI,
from my point of view I would run a try with the following scenario:
1) rule for https with advanced-balance ssl and probably application ssl. In terms of stickiness you have to check if this is needed or not.I've some trouble with such a rule but sofar it is not clarified if the trouble is caused by the servers or by the CSS.
2) rule for http traffic with balance domain(hash) or url(hash)
3) if applicable the same for ftp depending if your proxies support ftp caching.
Hope that helps.
Joerg
Hi Joerg,
Thanks for your reply. How would you code your solution? Currently I am using the following to work around particular sites:
service Proxy1
ip address 10.0.0.11
type proxy-cache
active
service Proxy2 ... etc
**************************** DQL ****************************
dql domains-no-balance
domain www.dontbalancethissite.com
domain ... etc
!*************************** OWNER ***************************
owner admin
content Proxy-servers
add service Proxy1
add service Proxy2
add service Proxy3
add service Proxy4
add service Proxy5
protocol tcp
port 3128
vip address 10.0.0.100
sticky-inact-timeout 5
balance leastconn
active
content no-load-balance
advanced-balance sticky-srcip
balance leastconn
add service Proxy1
add service Proxy2
add service Proxy3
add service Proxy4
add service Proxy5
protocol tcp
port 3128
url "/*" dql domains-no-balance
Ben
if you're talking about HTTP traffic, the best solution is arrowpoint-cookie with persistence disabled and persistence reset remap so the CSS can reconnect to a new server transparently.
The config should look like this
add service ...
vip address x.x.x.x
proto tcp
port xxx
no persistent
advanced-balance arrowpoint-cookie
I believe that for SSL traffic, your clients will use the same proxy port and the command "CONNECT HTTPS://..." and hopefully this solution should work as well [not sure so - I have a doubt and a test would be necessary to confirm this - will do it next week when I get back from vacation :-) ]
Gilles.
I havent managed to test all SSL websites but the one I am having trouble with is
http://www.emasys.dfes.gov.uk/ this will not work if there are any active rules with advanced-balance in. I am not sure why this is - that website also seems to instantly redirect to https. Any thoughts?
you'll need to sniff in front of cache and on the client at the same time then compare the result to see what's going on.
If the cache is receiving all the request sent by the client, then you need to focus on the cache.
If the cache is not receiving the request, we need to focus on the CSS.
Anyway, the sniffer trace is required.
Gilles.
Hi Giles,
I have resorted to using sticky-scrip and just one content rule as all web sites work with this configuration. However, this has the unwanted side effect of evenly balancing the traffic. Is there any way to smooth the balancing but still use sticky-scrip?
NO !!!
Follow our suggestions and sniff the traffic to get a clear understanding of the problem.
With proxy, the only good solution is cookies.
Gilles.
Setting up sniffing on this traffic is not that simple and schools need a working solution so I have to do something to get it to work :) I would be interested to hear what you have against sticky-scrip and why you think the cookie is the way forward?
sticky-srcip is ok but then you get unequal loadbalancing because of proxies [multiple user behind a single ip address].
Sticky based on cookie will assign a cookie to each user whatever their ip address. So much better for HTTP.
Gilles.
