Odd - SSL connections to some FARMS work, but not to others!
sgonsalv
I have been able to successfully test two SSL-PROXY services for my two test farms on our SSL module. However, when i try applying this to a production farm, namely FARM-VISTA-TEST as detailed in the attached config files, i've noticed that the HTTP connections work, but the HTTPS connections don't initiate the SSL connection, i.e. doesn't bring up the certificate etc. It just sits in the "discovering" state, where the bar at the bottom of the browser says "connected to 130.194.11.122..."!
At the moment the real servers in the FARM-VISTA-TEST have failed the probe, so the HTTP connections aren't avaliable, but, if you wanted to test the HTTPS connections from your browser you can. Note, you can also test connecting to my two test farm setups.
- Just wondering if there is anything in my configuration of the service for FARM-VISTA-TEST that stands out???
- Also would the type, or setup of the real servers in this farm have any bearing on the SSL connections to it??
FYI, we have two SSL modules, but for testing purposes i've only been using one SSL module.
Any help on this would be much appreciated.
thanks
6 Replies 6
sgonsalv
Hi Giles,
Have another question:
- When setting up Virtual servers, is it essential to state what the VLAN is? For example, with
vserver VVISTA-TEST-80
virtual 130.194.11.122 tcp www
serverfarm FARM-VISTA-TEST
vlan 11
sticky 60 group 225
replicate csrp sticky
persistent rebalance
inservice
is it essential to have the line "vlan 11" there? What does stating a VLAN here mean or imply?
thanks
the vlan is there to limit access to the vserver from a specific vlan.
If you do not specify a vlan, the CSM accept connections from every vlan.
Gilles.
Gilles Dufour
you are using the wrong sticky group.
In your config, I see group 225 being used with "vserver VISTEST-SSLVIP" and group 225 is " sticky 225 cookie JSESSIONID timeout 60".
So the CSM is waiting for a cookie in the HTTPS traffic.
There is no way to find a cookie in encrypted traffic.
You're working vserver - " vserver SSL_VIP" is using sticky group 100, which is SSL id stickyness.
Gilles.
Hi Giles,
Thanks for the information.
So going on what you are saying, setting up a sticky connection based on an SSL ID allows stickyness between the "clients" and the "SSL modules" itself, but there is no way of having that flow onto stickyness to the real servers themselves? That is, there is on way of having cookies at all with SSL connections?
thanks
Further to my previous note, if i setup the following:
nat server
no nat client
predictor leastconns
description WebCT-Vista Test-ServerFarm
failaction purge
real 130.194.13.241
inservice
real 130.194.13.242
inservice
real 130.194.13.243
inservice
real 130.194.13.244
inservice
real 130.194.13.245
inservice
real 130.194.13.246
inservice
probe VISTA-TCP-80
serverfarm VISTESTSSLFARM
nat server
no nat client
real 172.16.11.11
inservice
real 172.16.11.12
inservice
sticky 101 ssl timeout 30
sticky 60 group 225
inservice
vserver VISTEST-DECVIP
virtual 172.16.11.101 tcp www
inservice
virtual 130.194.11.122 tcp https
sticky 30 group 101
ssl-stick offset 20 length 6
inservice
- would having one virtual server "VVISTA-TEST-80" (HTTP)using a cookie based stickyness, and the other "VISTEST-SSLVIP" (HTTPS) using an SSL based stickyness cause a problem?
- If the above causes a problem, i guess the group that owns the FARM-VISTA-TEST farm would need to remove the cookie based stickyness from their servers to allow an SSL service to work?
- Is there an alternate way of having stickyness to the real servers if cookies aren't the way?
thanks
Sheldon
your solution is correct.
You have to use ssl stickyness for ssl [HTTPS] traffic and the decrypted traffic [HTTP] can be then stuck to a specific server using cookies.
Gilles.
PS: please rate all answers you are receiving - it helps others find useful information and it is also a motivation to know that our help is appreciated.
