a problem with ACL in the class-map on the ACE module
ROMAN TOMASEK
                  Hi all,
I configured the following on the ACE module:
object-group network test
  host 192.168.1.21
  host 192.168.1.22
  host 192.168.1.23
object-group service port
  tcp eq www
  tcp eq 8080
access-list T line 8 extended permit object-group port object-group test any
I tried to configure a class-map for matching this ACL:
ACE-4710-2/Lab-OPT-11(config)# class-map match-any TEST_C
ACE-4710-2/Lab-OPT-11(config-cmap)# match access-list T
Error: Cannot associate acl having object-group ACEs in class-map.
So couldn't I  configure the class-map by using ACL with object-groups involved? Is it the bug or the normal behaviour? Because the customer uses object-groups in ACLs and he has to configure ACL without object-groups for the traffic classification. It is horrible.
Thank you
Roman
Daniel Arrondo Ostiz
Hi Roman,
I'm afraid it's the expected behavior. You cannot use an ACL with object-groups inside a class-map.
Daniel
