Ability to ping redundant interface IP address
ben.robinson
I have this setup for our content switches.
Primary F/W --> Primary CSS --> Local Switches
Secondary F/W --> Secondary CSS --> Local Switches
This is the relevant configuration.
Primary CSS
circuit VLAN4
ip address 192.168.76.4 255.255.255.0
ip virtual-router 4 priority 101 preempt
ip redundant-interface 4 192.168.76.254
Secondary CSS
circuit VLAN4
ip address 192.168.76.5 255.255.255.0
ip virtual-router 4 priority 90
The problem is that the Secondary F/W can not ping the redundant interface IP address via the secondary path when all devices are in normal mode.
Is this normal?
The ping is occuring for firewall failover checking.
Ben
Gilles Dufour
it should work.
Your diagram does not display very well, so I don't know where are the | links.
What should be the path of traffic from secondary firewall redundant-interface ?
Is the traffic going to 1 CSS and being bridge to the 2nd CSS ?
If that's the case, you need the command 'ip uncond-bridging' on both CSS to force CSS to bridge first and then route.
Gilles.
