Access to rservers behind ACE
AlexandrKry
I have ACE 20 in 6500 configured in routed mode, similar to configuration described here: http://docwiki.cisco.com/wiki/Basic_Load_Balancing_Using_Routed_Mode_on_the_Cisco_Application_Control_Engine_Configuration_Example
There is a context that has the following VLANs assigned:
Vlan 100 - management interface: 10.0.100.1/24
Vlan 101 - client side interface: 10.0.101.1/24
Vlan 102 - server side interface: 10.0.102.1/24
I have VIP configured (10.0.101.10) and two rservers (10.0.102.11 and 10.0.102.12) in a single server farm.
Servers have 10.0.102.1 as their default gateway.
Load balancing works fine, client connection reaches the rservers via VIP.
My problem is that I cannot connect to real servers behind ACE (10.0.102.11 and 10.0.102.12) directly, without load balancing involved.
The ACE just blocks all the traffic not destined to VIP, although ifaces vlan101 and vlan102 have "permit ip any any" input ACLs.
What else do I need to configure to make this work?
It worked when interfaces 101 and 102 were in bvi, but I need to have multiple contexts with shared vlans.
16 Replies 16
There is one thing I missed out again.
/32 routes on 6k are still necessary if you want to use a single Vlan across multiple contexts whether or not you use dedicated interfaces on servers for management.
I should clarify this again for someone who get stuck as I did
You can use the same server Vlan for multiple contexts without host routes. To do that you need to have different subnets for each one of them (even though I'm not sure it's a good design).
My solution is to split the server's /24 network into multiple /28 networks and add appropriate routes on 6k.
This way you won't need to add a static route every time you add a server to the context.
