Accessing ACE30 through Https for management
rhussaini
I am new to the ACE30. I a basic configuration from the CLI and I am trying to use the device manger. I am able to get to the web informational page rather then accessing the login page.    I have rest the password for both the admin and www and still no go. my question is how to go into enabling the GUI access.
Thank you for your help
jackwikinski
Level 3
Level 3
If I understnd you correctly you wish to manage the ACE via the GUI as well as the CLI.
The only way to do this is to use a product called ANM (Application Networking Manager).
In the setup you can specify http, https access. the toll allows you to configure and monitor the Ace devices.
Hope this Helps.
Thanks.
Jack.
