ACE 4700 and Cisco ACS aaa authentication
cisco24x7
Level 6
Level 6
ACE version Software
loader: Version 0.95
system: Version A1(7b) [build 3.0(0)A1(7b)
Cisco ACS version 4.0.1
I am trying to authenticate admin users with AAA authentication for ACE management.
This is what I've done:
ACE-lab/Admin(config)# tacacs-server host 192.168.3.10 key 123456 port 49
warning: numeric key will not be encrypted
ACE-lab/Admin(config)# aaa group server tacacs+ cciesec
ACE-lab/Admin(config-tacacs+)# server ?
<A.B.C.D> TACACS+ server name
ACE-lab/Admin(config-tacacs+)# server 192.168.3.10
can not find the TACACS+ server
specified TACACS+ server not found, please configure it using tacacs-server host ... and then retry
Why am I getting this error? I have full
connectivity between the ACE and the ACS
server. Furthermore, the ACS server
works fine with other Cisco IOS devices.
Please help. Thanks.
20 Replies 20
you do not have any other access to the device ?
What about console ? Do you also run tacacs on console ?
G.
This is what I did:
1- configure AAA configuration on the ACE box,
2- go to my Cisco ACS and stop the ACS service.
That enables me to log into the ACE box with
"admin/admin",
3- enable Cisco ACS service on the ACS server,
4- Now I can log into the ACE box with ngx1
account. However, I can not go into the
"conf t" mode.
Can anyone help? Thanks in advance.
next thing is to get a sniffer trace of the TACACS exchange.
We'll need the key to decode.
You can also try to upgrade to A1(8a) or A3(1.0).
Finally, a service request with the TAC seems appropriate.
Gilles.
I found the following in the ACE 4700 release notes:
CSCsl48103-When the ACE is configured for TACACS+ authentication with a user context and the Cisco ACS sends the cisco-av-pair* attribute before the ACE custom shell attribute, you cannot log in to the ACE via TACACS+ and use the Admin role. Workaround: Do not use the ACE TACACS+ authentication for an Admin role. If you must use TACACS+ authentication for an Admin role, do not configure the Cisco ACS to send the cisco-av-pair* attribute.
www.cisco.com/en/US/partner/docs/app_ntwk_services/data_center_app_services/ace_appliances/A1_x/release/note/RACEA1X.html
Ross
Are you saying that I do NOT need in Cisco ACS:
shell:Admin*Admin default-domain
