ACE 4710 A3.2.5 and unknown script error (30009)
swiss_ewok
Community Member
Hi all,
i've got a problem with scripted probes. In two contexts i have configured the same scripted probe:
probe scripted PRO-SSL636
  port 636
  interval 5
  faildetect 2
  passdetect interval 10
  passdetect count 2
  receive 3
  script SSL_PROBE_SCRIPT
In one context it work's fine, in the other one I get the following error:
serverfarm  : SRF-LDAPS
     real      : SRV123-DOMAIN-COM[0]
                192.168.0.200 636   PROBE    0        0        0        INIT
   Socket state        : RESET
   No. Passed states   : 0         No. Failed states : 0
   No. Probes skipped  : 0         Last status code  : 30009
   No. Out of Sockets  : 0         No. Internal error: 16833
   Last disconnect err : Internal error: Unknown script error
   Last probe time     : Never
   Last fail time      : Never
   Last active time    : Never
The script SSL_PROBE_SCRIPT is located in probe: with other Cisco-Standard-Scripts.
Has anyone an idea ?
Thanks for your help.
swiss_ewok
amacuz
Level 4
Level 4
Hi Sven,
quick question: did you load the script also in the context where it fails?
Just check if you have "script file name
Hi Alessandro,
thanks for your answer. Yes, the script is loaded in the running configuration of the context where it fails:
"script file name SSL_PROBE_SCRIPT"
Are there another ideas ?
Thanks for your support.
Faithfully,
swiss_ewok
Hi Swen,
unfortunately the error code is of not of much help here and we would need to go through show techs and debugs.
Would be possible for you to open a TAC case? You can mention my name at the opening and I can take care of it.
Alessandro
