ACE 4710 FT Unit Management Access
santipongv
I believe I should be able to get into the management interface IP address of the ACE 4710 FT unit. However, I keep getting this message, "login is temporarily unavailable as startup configuration is being applied; try after some time ..."
I even tried to reload this FT unit, but still unable to get in. Does anybody know the reason why it is behaving this way and how can I gain access to the FT unit.
Thank you.
10 Replies 10
Gilles Dufour
did you try to login as admin ?
There is an open issue right now if you try with a different user.
CSCso00038: login is temporarily unavailable... for any user except "admin"
Gilles.
Yes, I also did try to log in as "admin" but was unsuccessfull.
The workaround from the ddts :
Have a non-redundant Admin context or disable running config sync on Admin context
Give that a try.
The ddts above will be fixed in A1.8 which should be out soon.
Gilles.
I did try disabling both running config sync and startup config sync in Admin context of the primary unit, but none of them work.
ACE4710/Admin# sh context
Number of Contexts = 1
Name: Admin , Id: 0
Config count: 290
Description: context for Admin
Resource-class: Admin
FT Auto-sync running-cfg configured state: disabled
FT Auto-sync running-cfg actual state: disabled
FT Auto-sync startup-cfg configured state: disabled
FT Auto-sync startup-cfg actual state: disabled
ACE4710-FO login:
Password:
Login incorrect
ACE4710-FO login: admin
Password:
Login incorrect
You just get the login is incorrect when trying with admin.
So seems like a pwd issue.
Gilles.
I have dafault username and password (admin -admin) on the ACE but the primary authentication method is TACACS. I was unable to use TACACS to authenticate my credentails so I used the default local admin account. I am certain that I typed in password correctly.
Disable the FT link and try to connect to the backup with your admin username.
If it doesn't work, it is a password issue.
If it does work, upgrade to the upcoming A1.8 and see if the problem persist
Gilles.
I disconnected the Crossover cable for FT , but I was not able to get it with local admin account until after I reload the unit. I believe I have to wait for the upcoming A1.8 version. Thank you.
ACE4710/Admin# sh ft group detail
FT Group : 1
No. of Contexts : 1
Context Name : Admin
Context Id : 0
Configured Status : in-service
Maintenance mode : MAINT_MODE_OFF
My State : FSM_FT_STATE_ACTIVE
My Config Priority : 110
My Net Priority : 110
My Preempt : Enabled
Peer State : FSM_FT_STATE_STANDBY_HOT
Peer Config Priority : 90
Peer Net Priority : 90
Peer Preempt : Enabled
Peer Id : 1
Last State Change time : Thu May 15 07:26:38 2008
Running cfg sync enabled : Enabled
Running cfg sync status : Running configuration sync has completed
Startup cfg sync enabled : Enabled
Startup cfg sync status : <===
