ACE 4710 How to replace an damaged unit in FT
We have two ACE 4710 working in the high availability scheme.
The main unit broke down and the standby unit took to active state as expected.
How can I replace the main unit without stop the services?
I couldn't find any documents with this procedure at CISCO.com.
regards
Jorge Bejarano
Level 4
Level 4
Marcelo,
Read this following thread, it is very useful and has most of the details which you need to know:
https://supportforums.cisco.com/message/3669014#3669014
Hope this helps!
Jorge
5 Replies 5
Cesar Roque
Level 4
Level 4
Hi Marcelo,
You need to have the same code and same license on both ACEs
In the new ACE you have to configure the physical interfaces and the FT cofiguration.  Enable preempt in case it is disable on the production ACE.
The only thing you need to take care is with the FT priorities, the new box must have lower priority than the one in production.
This way the configuration will get sync from the Active to this new ACE
If you have SSL certificates, you have to import those to the new ACE manually
Cesar R
ANS Team
--------------------- Cesar R ANS Team
Hi Cesar,
I'll check your tips.
Thanks for help!
Jorge Bejarano
Level 4
Level 4
Marcelo,
Hope this helps!
Jorge
Hi Jorge,
This thread has a step by step procedure and it will be very usefull.
I'll check it.
Thanks for faster reply.
Marcelo,
It sounds good then.
Jorge
Please mark it if it is useful then other users can use it as reference in the future
