ACE 4710 Issue
Ali Bahnam
Level 5
Level 5
Dears,
I have Cisco 4710 configured, but my issue that I can't ping the Virtual IP.
Attached the configuration of the ACE4710.
Appreciate you support,
Regards.
pablo.nxh
Level 8
Level 8
Hi Ali,
I'd check on the status of the rserver/serverfarm since you configured a TCP probe under the serverfam but no port was specified either on the rserver/serverfarm or the the probe itself. Likely the status of the serverfarm is not operational.
__ __
Pablo
7 Replies 7
is the issue only with icmp to VIP or applications on VIP are also not accessible?
For now the issue is I can't ping the virtual IP from the client side.
Ali,
What´s the VIP in question? Can you paste it in here?
do u have any firewalll in between client network and VIP blocking the ping?  Also i dont see source nat configured for client request accessing servers.
have u created resource class for stick connections in admin context?
resource-class sticky
  limit-resource all minimum 0.00 maximum unlimited
  limit-resource sticky minimum 10.00 maximum unlimited
This is mandatory if u r using sticky based serverfarm in user contexts
pablo.nxh
Level 8
Level 8
Hi Ali,
__ __
Pablo
I added the port it is working now.
Thank you
