ACE 4710 Long Timeout
magordon
I have a redundant set of ACE4710's and if a user is connected to a particular host behind the LB's and I take that host manually out of service via the LB the client is unable to reconnect to one of the oter servers serving the same application for some time (approx 2-5 minutes). Is there a way to expidite this so as soon as a host is taken online the other hosts will take up future connections from the client?
Thank you in advance,
Matt
5 Replies 5
Hi Matt,
If you use the sticky connection , and you do not set a action when a rserver fails you have a problem.
If your case is the one described by me , then the solution is setting on serverfarm config : failaction purge.
Dan
Dan,
I am using sticky connections, and I do have "failaction purge" set. It still seems to take a bit before the client can reconnect...
I attached the config for that context, slightly modified for some security purposes...
Thank you,
Matt
Matt ,
Correct me if i am wrong :  the problem is that when you switch a rserver to outofservice, the client(s) connected to this rserver cannot connect for 2-3 minutes?
Are stoping the application on that server or do you gracefull shutdown from the ace ?
After taking the rserver outofservice can you check the sticky connections : sh sticky database rserver $rserver  $port serverfarm $server-farm
Also can you see any connection to the server : sh conn rserver $rserver?
Dan
Also ,
From : http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/slb/guide/rsfarms.html#wp999576
The no inservice command instructs the ACE to do the following:
Tear down existing non-TCP connections to the server
Allow existing TCP connections to complete before taking the server out of service
Disallow any new connections to the server
Dan
Dan,
I see no entries in the sticky database. I am using the ACE to set a client side session cookie, which I can see in the browser, but it does not log an entry in the sticky table... I see approperate connetions when I do a sho conn though...
Thank you for your help so far,
Matt
