ACE 4710 multiple services running on load balanced Servers
Our Exchange 2010 hub servers run multiple services/ports:  smtp, www, pop3,135, 143, https, 993, 995, 6001,6002,6003,60200,60201,8400, and 8402
what is the best way of balancing these servers so that if only one of the services failed on a server, it would switch only the failed service to remaining servers.
At present I only use an smtp probe, so as log as that sevrice is running the server is marked good. It seems to me the setup could get quite complicated so any responses welcome.
Jorge Bejarano
Level 4
Level 4
It is hard to say without checking the configuration first, but we can try to configure a customized class-map, policy-map, serverfarm,etc to hear on the specific ports which you are using, meaning, you can have specific configuration based on each port which you are using, without affecting the rest, that would be the best way I would say since it will be focused on each port and not a mixed of many ports.
Just imagine a probe for that, what would it be supposed to check if it has many ports configured? You see what I mean (Divide and conquer would be the best)
Please attach the configuration related to the issue then we can have a better idea about what you mean and what you are looking for.
Jorge
Jorge,
Please see config below
logging enable
logging buffered 5
logging monitor 5
access-list ALL line 10 extended permit ip any any
access-list ALL line 18 extended permit icmp any any
ip domain-name simplot.com.au
ip name-server 172.16.7.210
ip name-server 172.16.5.228
probe icmp icmp
interval 7
faildetect 2
passdetect interval 30
passdetect count 2
receive 5
probe tcp tcp25
port 25
interval 20
passdetect interval 60
passdetect count 2
open 1
rserver host chihub73
description hub73
ip address 172.16.6.196
inservice
rserver host chihub74
description hub74
ip address 172.16.6.197
inservice
serverfarm host Exchange
description DSI servers
failaction purge
probe tcp25
fail-on-all
rserver chihub73
inservice
rserver chihub74
inservice
sticky ip-netmask 255.255.255.255 address source Sticky
serverfarm Exchange
class-map type management match-any EXCH
201 match protocol snmp any
202 match protocol https any
203 match protocol telnet any
204 match protocol icmp any
class-map match-any EXCH_vip
2 match virtual-address 172.16.93.2 tcp eq smtp
3 match virtual-address 172.16.93.2 tcp eq www
4 match virtual-address 172.16.93.2 tcp eq pop3
5 match virtual-address 172.16.93.2 tcp eq 135
6 match virtual-address 172.16.93.2 tcp eq 143
7 match virtual-address 172.16.93.2 tcp eq https
8 match virtual-address 172.16.93.2 tcp eq 993
9 match virtual-address 172.16.93.2 tcp eq 995
10 match virtual-address 172.16.93.2 tcp eq 6001
11 match virtual-address 172.16.93.2 tcp eq 6002
12 match virtual-address 172.16.93.2 tcp eq 6003
13 match virtual-address 172.16.93.2 tcp eq 60200
14 match virtual-address 172.16.93.2 tcp eq 60201
15 match virtual-address 172.16.93.2 tcp eq 8400
16 match virtual-address 172.16.93.2 tcp eq 8402
policy-map type management first-match EXCHANGE
class EXCH
permit
policy-map type loadbalance first-match ldap-slb
class class-default
sticky-serverfarm Sticky
policy-map multi-match multi-vips
class EXCH_vip
loadbalance vip inservice
loadbalance policy ldap-slb
loadbalance vip icmp-reply
nat dynamic 6 vlan 93
interface vlan 93
description client server vlan
ip address 172.16.93.4 255.255.255.0
peer ip address 172.16.93.1 255.255.255.0
access-group input ALL
nat-pool 6 172.16.93.8 172.16.93.20 netmask 255.255.255.0 pat
service-policy input EXCHANGE
service-policy input multi-vips
no shutdown
ip route 0.0.0.0 0.0.0.0 172.16.93.254
snmp-server contact "Comms team"
snmp-server location "Chifley park CR"
snmp-server community OVSimplot group Network-Monitor
snmp-server trap-source vlan 93
I would say if you can break it down like this:
class-map match-any sample_vip_135
2 match virtual-address 10.10.10.2 tcp eq 135
serverfarm host Exchange_sample_vip_135
failaction purge
fail-on-all
rserver sample1 135
inservice
rserver sample2  135
inservice
As you can see, you can specify the vip for a specific port, then you need to configure a policy for load balance and add it under the policy multimatch in question, and the rest of the config in general. You can create a serverfarm focus on each port and you can specify the port.
Hope this helps!!!
Jorge
