How to restore the default settings?
the ACE 4710 is running 3.2.5 and I need to put it in another environment.
Is there a way to reset its settings?
regards
Jorge Bejarano
Level 4
Level 4
Hello Marcelo,
You need to make sure about some things first:
-Remove licenses
-Remove SSL files(keys, certs, etc)
Then you can run #write erase or #clear startup-config
Additionally, here you have a link with some extra information:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA1_7_/configuration/administration/guide/managesw.html
Good Night Jorge
Jorge Bejarano
Level 4
Level 4
Hello Marcelo,
-Remove licenses
Good Night Jorge
Hi Jorge, thanks for a quick reply.
A single command I had forgot.
Many thanks for the important tips about licenses and keys.
Sure
Jorge
